I need your opinions on this one. Motor HJ/NSKK Driver Badge.
275
61
Obergebiet Mitte, USA
Guys,
I need some help here.
The seller has given me permission to post the image on the forum.
Opinions???
Thanks much!
kevin
Kevin, here's a link to an NSKK badge similar to this one. Looks pretty similar to the one you posted.
Admin edit: picture no longer available on external site
Here's another NSKK diamond insignia and the alder is really close to the one you posted Kevin, the roundel with the swaz is sort of "stretched" like your HJ example.
looks excactly the same as one i have , that came from a good source
2nd pattern hj/nskk insig revisited
Guys,
Let's re-visit this one.
As you recall [in this thread] the consensus from the photos I supplied on this 2nd pettern hj/nskk insignia was that this was an ok piece.
I received it and put it against my 1st pattern hj/nskk insig.
This photo was taken with my phone so it's not the best, but I think it will serve the purpose here, as it was taken in the dark.....with a black light.
The first pattern on the right was completely dead under the light.
The second pattern on the left? Well you can see for yourself.
It was not a streaking kind of flourece that one sees when something is laundered with modern detergents, it was bright, purple and uniform.
So now what are your opinions with this added piece of information?
I'm not very comfortable with it.
The seller is kind enough to accept the return.
Let me hear your thoughts on this one.
kevin
That's unnerving to say the least Kevin. Did you try and set it next to a piece of known modern white cloth like a sock or t shirt for comparison?
well, it is good to know that you will have a refund. Happy days.
But, that test is conclusive?
Antonio
Antonio,
The black light is only one vote.
I suppose I could have burned a little piece of thread and see if it melted or produced ashes.
The UV test results put enough doubt in my mind, that this piece will find its way back to the seller.
kevin
