Hj honour badge - HJ-Ehrenzeichen opinions
Apr 3, 2016
11
8
Stein, Netherlands
Hello fellow collectors,
Today i got this golden membership badge. It looks like the pin has been replaced at some point. Am i correct, or what do you think about this badge?
Thanks for your help,
Sander
This has the stipple spacing found on M1/49 Baumeister badges but the "RZM" placement is different. I dunno. Could this be an M1/120 Deumer instead? Can you see any remnants of the MM?
Thanks for your reply. Yes i do see some remails of the mm number, very hard to tell and only see a part of the last number. Could be an 8, maby a 9. But cannot tell.
Well, that's a difficult one. To me it looks like this is a Deumer with the RZM stamp and maker mark placed in a different position (on both outer sides of the pin. You find this type quite often and some collectors are very sceptical about it albeit the dot pattern looks pretty much the same as on the accepted Deumers.
Yep, its a hard one. You are correct about the RZM stamp. There are some remains on both sides of the badge. And the dotting looks good.
Sander.
I would pass on this one and look for one with the marks on the back with known makers.
