My finally completed HJ bust. Bann 40 / Gefolgschaft 20
Vidar
Dec 7, 2025
40
10
14
Here is my Bann 40 / Gefolgschaft 20 display with original Sud Württemberg HJ triangle. which I finally completed. It is all original stuff, except a couple things I haven't found.
-The original stuff-
*Bann 40 / Gefolgschaft 20 HJ shirt with shoulder strap and multi part hankenkreuz hj armband.
*Original M1/13 membership diamond.
*Leather shoulder strap.
*Leather Belt with the rare RZM M4/118 marked HJ Zinc die cast buckle with die added M.
*RZM marked M31 canteen with M31 bread bag.
*Sommermütze RZM tagged Hersteller 11 with HJ Membership Badge RZM M1/102 marked.
*HJ bakelite whistle with original strap.
* Puma transitional double marked HJ knife m7/27 1937 with motto.
* 3 original black belt loops.
-Reproduction until proper originals found-
* HJ/BDM Scarf
* Homemade (Myself) original style brown leather woggle.
* HJ black corduroy HJ shorts.
Hope everyone enjoys, it took a few months to complete after several orders from Europe and the U.S... This is my first completed mannequin, Hopefully I can find a verified original scarf and woggle, along with some shorts someday?
Very nice uniform, and it looks well-matched.
Thanks for your replies fellas. It was a very enjoyable build, spent more than I should have and went through 3 mannequin bust forms before I found one that looked right IMO but I think the end result is incredible and museum like display which I had hoped to achieve... It appears this unit was in the south of Germany between Stuttgart and Lake Constance (Bodensee). I think it would basically be considered a Allgemiene - HJ and just a lowly Hitlerjunge. It would be phenomenal to create a HJ Jungzugführer, Gefolgschaftsführer next. I'd like to find a nice parade uniform for this, brocade belt and the works. Hopefully at the Max I can find some decent stuff?
Cheers,
Adam
Nice uniform VIDAR .
I can only make a small criticism (sorry!). The red and white cord of Kameradschafsfuehrer and Oberkameradschaftsfuehrer is the only one that is worn from the button of the right pocket to the third button on the front of the shirt.
I appreciate the criticism. I'll fix it tomorrow. I have seen that and most period pictures previously but since it arrived that way I just never changed it yet and I honestly wondered if someone would say something? Now I know the answer. 😂 Thanks for the criticism and compliments!
Is this correct now?
Thanks for the help,
Cheers,
Adam
Perfect !! Sometimes it's the last little detail that makes all the difference. :clap2:
Awesome thank you! 😎 It does look better, it shows up like it should and isn't so sloppy looking!
Cheers,
Adam
Looks fine. If you want to add the final touch, run the cross strap over the scarf.
And as there’s a whistle on the Kameradschaftsführer lanyard, I’d simply tuck the end with the whistle into the breast pocket. That’s how it was done – otherwise, how else were you supposed to use the whistle?
In the long run, I’d try to get hold of a RZM regulation toggle with 4/3 layers visible. Yours has 3 all round. Then everything will look perfect.
Does this look better in your opinion? I am a bit confused, are the original woggles 4 leather stripes wide of 3? I thought they were supposed to be three? Do you have a picture of a known original or a good link to one? I made the one in the picture until I find an original RZM woggle and scarf.
Thanks,
Adam
I made a new woggle to temporary don on my HJ uniform bust until I can find an original. Is this one look closer to the proper style of the original 4/3?
Thanks, because that's one subject I'm quite frankly not at the top of my game on.. Most without a RZM mark are IMO impossible to prove or know they are actually genuine. That's why I haven't invested in a "real" one, yet... Perhaps I find one someday that convinces me after I research the page you've linked? Thanks again...
This graphic should also be of some help to you. How is the inside of your woggle tied?
I tied mine with cotton string... I think the new one I made will do well until I find one that satisfies me until I can find a legitimate real one .. thanks again Jack..
Hi Adam,
Yours in #12 appears to have four visible layers on the underside. That would be a good match.
By the way, the yellowish RZM-compliant ones aren’t actually that hard to find.
With a bit of luck, you might even find one with an RZM tag.
Awesome thanks I'll look. Just spent a bunch bought a super nice NSDAP flag bearers gorget, so I'll need to look for a nice one to buy around my next pay check ..
Regards,
Adam
