Does anyone recognize this tornister pattern?
AHR
Apr 21, 2021
24
8
I purchased this thing on eBay a year or two ago before I learned anything - rookie mistake, guilty. At the time, I thought from the nice fur and earlier tab arrangement for the Kochgeschirr that it was an earlier model. Then it arrived and I was perplexed. It was sold without straps, but when I went to replace them, I discovered the slots for the shoulder straps were too narrow! I finally found a narrower set of straps sold by a gentleman in France that fit it perfectly - and those turned out to be RZM marked. (The wider strap in the comparison photo is a reproduction, but it matches in size and shape to the straps from an RZM original tornister I had at one time.)
So.. what is this thing? Assuming the narrower straps were originally made for a pack like this, I wouldn't think the design at least was post war, even if this particular model might be. I'd originally thought perhaps this was a political pattern - something intended to fill out the ranks in newsreels but that wouldn't actually be carried out on into the countryside for actual use. However, the PL pack specifications I found in the '36 RZM guidelines uses the normal wider straps that hook onto a belt in front.
There's no maker marks on the pack itself I can find. Some of the leather looks a bit artificial, but I'm not sure. The rivets in place of stitches suggests midwar or later, do they not? Also I'm not certain, but I think that red reinforcing strip you see at the inside top of the main body is cardboard of some kind rather than rawhide, and I don't see the nettle cloth wrap on the wood.
So what is this? Some mid/late war hodgepodge from available tooling and materials? A niche homemade political item? Some auxiliary pattern that was never important enough to document? Even a postwar movie prop or Eastern European tourist bait or something? For what it's worth, the last owner says it was sold by a militaria company in California, but has no idea what its earlier history was. Oh - and the long fastening straps on the flap look to have gotten a lot of use, though that could have just been from a kid using it from a bookbag in later years.
Could this be the M34 SA Tornister? Wim Saris would be able to say whether it is or not I would think.
  • Like
Reactions: AHR
Oh well. Thank you both regardless!
I'd wondered if it was SA because of the color, but the '36 specification at least still had I think the cartridge pouches in the flap, which this lacks. And the various construction shortcuts (rivets, cardboard, no fabric reinforcement on the frame) still have me thinking mid-late war, or knockoff.
Speaking of, I ran across a photo a while back of a bunch of BDM girls on a train platform for camp, and you can see the cartridge pockets on one girl's tornister. The photo wasn't dated, but I imagine they were still using WWI leftovers at that point. Or at least the poorer kids that had to borrow from the organization were.
Oh! I had been meaning to ask - is there some question over the SA Tornister pattern?
When I was looking in the RZM regulations for HJ stuff I saw something that confused me in the description for that one. I'm sure I misread some Fraktur some characters and the translation is from Google, but here's the excerpt:
Zur befferen Haltbarfeit diser Schlaufen sind auf der unteren Seite
des Deckels vier Lederstüde in entsprechender Grösse unterleft. Die
Schlaufen dienen zur Befestigung der Kochgeschchirrriemen. Die vier
äusseren für das quer auszulengede grosse Kochgeschchirr, die zwei
mittleren für das quer auszulengede kleine Kochgeschchirr. Jeweils
drei Schlaufen liegen nebeneinander. Die Schlaufen sind von der
äusseren Kante des Deckels 7 cm entsenrt angebracht. Die sechs
Schalufen tönnen auch in zwei ganzen Stucken ausfenäht werden; aussen
und jeweils zwichen den Schlaufen sind dann je zwei Nähte zu vier
Stitchen.
To increase the durability of these loops, there are four leather
studs of the appropriate size on the lower side of the lid. The loops
are used to attach the cookware straps. The four outer ones are for
the large cookware that is laid out crosswise, the two middle ones are
for the small cookware that is laid out crosswise. There are three
loops next to each other. The loops are placed 7 cm away from the
outer edge of the lid. The six loops can also be sewn out in two whole
pieces; On the outside and between the loops there are two seams with
four stitches each.
Anyhow, I recently chanced across a listing that more or less matches that description:
The interior canvas is gray, not brown as per the specification - but the construction details seem to match.
Maybe it's late Reichswehr? I assume with the cartridge pouches it's not RAD.
If this is all well-known material, sorry for the digression.
