Flak helper HJ cap
May 16, 2024
58
7
Hello, I would like to present this HJ Flak Helper cap. I am quite happy with it but I would appreciate your expert opinions on it please. Thanks, Andreas.
It looks to be more then common dark grey.
The cloth fabrik inside, most if the times is shiny, this is not
This type of rbn stamp is not often seen.
Very nice rzm label..
textbook setup..
In my opinion a winner!
Indeed Werner, I too am not familiar with this kind of lining and RbnR marking.
Enthusiast ,Look at this thread to compare
I tried to make a longer answer, but then it blocked , because I am no Blue member
See attachment
Contrary to popular belief, Lorem Ipsum is not simply random text. It has roots in a piece of classical Latin literature from 45 BC, making it over 2000 years old. Richard McClintock, a Latin professor at Hampden-Sydney College in Virginia, looked up one of the more obscure Latin words, consectetur, from a Lorem Ipsum passage, and going through the cites of the word in classical literature, discovered the undoubtable source. Lorem Ipsum comes from sections 1.10.32 and 1.10.33 of "de Finibus Bonorum et Malorum" (The Extremes of Good and Evil) by Cicero, written in 45 BC. This book is a treatise on the theory of ethics, very popular during the Renaissance. The first line of Lorem Ipsum, "Lorem ipsum dolor sit amet..", comes from a line in section 1.10.32.
The standard chunk of Lorem Ipsum used since the 1500s is reproduced below for those interested. Sections 1.10.32 and 1.10.33 from "de Finibus Bonorum et Malorum" by Cicero are also reproduced in their exact original form, accompanied by English versions from the 1914 translation by H. Rackham.
I posted as "Tester" and as you can see, I was able to post long messages using a test account that has the same permissions as yours. I posted from an Android mobile.
PS The Blue Group message will sometimes appear even when the event that caused it has nothing to do with Blue Group access. This might be when a member attempts to use a function for which he does not have the necessary permission. Difficult to know what is causing it for you.
