These are some DJ Hordenführer Winkel. The regulations regarding this insignia are dated 4, April 1934. The initial regulations did not address any form of underlay, however a regulation dated 24 January 1936 specified that this insignia was to be worn over any specialty sleeve insignia. This regulation also introduced an underlay in the color of the fabric that the insignia was worn on, each side measuring 5cm. The underlay was specified to be worn on the brown shirt but not the blouse or overcoat. The 8mm wide aluminium tress was spaced 2mm from the outer edge of the underlay. The regulations also specified that a "TA" blue RZM tag was to be afixed to the backside. The chevron was worn until April 5, 1939, when the new pattern round ranks fully came into effect. These should not be confused with the "Alter Kämpfer Winkel", which is slightly larger and of a different pattern. Edit, most of this information came from Angolias HJ, so it may not all be correct.
